I am using EDT output with a Tableau’s template. It some circumstances I need to feed a new set of data using EDT transform but my problem is that in the original Tableau’s template I refers to Sheet1 but EDT changes the name to Easy Data Transform. Is there any way to keep Sheet1?
EDT is a powerful program with a graphical UI, nevertheless to manipulate complex data you have to spend thoughts as you have to to for some complex options which you saw in the Unique discussion in another thread.
Doing so I think it is not unreasonable to think by your own on the square brackets, which give you specially a lot of option when you write multiple files out of one program/table. I‘m not a fan of an option field which would be used only for one output format.
Aa an alternative which might be feasible, in case of Excel output „output.xlsx[EasyDataTransform]“ is offered as default and therefore the user recognise and remember the option to chose the sheet.
