Hi, This is can I do either or question. Any of these solutions would work for me.
I have a column that has 5 YES and 7 NO. Is there a way to add up how many YES are in the column and put the total of 5 at the bottom of that column?
I have a column that has 500 YES in it. Is there a way to have the 500 display at the bottom of that column?
I know I can filter but I need the total number in the spot so I can import the sheets data into MS publisher.
Thank you
Kim
