The function Replace, replaced "&" with "Nothing"
The function Replace, replaced the & in the row, with “Nothing”.
If i have two: “&&” that make in the Replace “&” only one, what I need.
Maybe an issue?
Thank you for reading and your time
Is this what you mean?
If you want to replace any number of ‘&’ chars with one, you might need to use a regular expression.
Oh, no.
I have html, with “&” in the inside. Normal only one &!
But, I’ll not replace the “&” with something!
The Replace function delete them!
Beside the SOMETHINGTOREPLACE&SOMETHINGTOREPLACE&SOMETHINGTOREPLACE&
The Replace function make: REPLACEDTEXTREPLACEDTEXTREPLACEDTEXT
without the “&”
Can you show a few rows of input and the corresponding output that you want.
I want to create a Test Table, but, there is the replace function correct.
With my real data, the & was deleted.
I still don’t understand what you are trying to do. If you could paste in here a few rows of inputs and the outputs you want for that input, it would help.
