Sum of hours, minutes and seconds
At my work we use a system for time tracking.
It outputs data in this format:
00:30:00
00:15:00
02:15:00
00:45:00
03:15:00
00:45:00
so it is hours:minutes:seconds
I would like a sum of the column, but still in the same format.
Is it possible without having to first convert the time to a decimal format, sum it up and convert back to hours:minutes:seconds?
don’t see a transformation for it. But I think it is not easy, as you need to define rules for calculation if hours sum up for more than 24. I think conversion into decimal numbers is the saver way. But maybe Admin has something in the pocket we don’t see.
You can do it using Calculate with modulus and divide functions. But it would be very long winded.
Probably better to do it with some Javascript:
sum-times.transform (3.8 KB)
In the Calculate transform we have MSecsToDateTime and DateTimeToMSecs functions. Perhaps we also need:
-a TimeToMSecs function, e.g. that would convert “00:01:00” to 60000.0.
-a MSecsToTime function, e.g. that would convert 60000.0 to “00:01:00”.
That could also help me in this use case.
Here is my take on it. I am assuming that you want the sum at the end of the column, if it is not the case then @Admin solution is enough.
Transform file.
SumTime.transform (4.3 KB)
I have added TimeToMSecs and MSecsToTime fucntions to the Calculate transform. These will be available in the next release and should make time-based arithmetic like this a lot easier.
Brilliant!
I took the liberty to add an If statement that adds :ss in case only hh:mm (no seconds) were used as input - this works for 24h format only, no AM/PM
(matching regex: ^(?:[01]\d|2[0-3]):[0-5]\d:[0-5]\d$).
See enclosed.
sum-times-2.transform (5.0 KB)
Or, if you can live with a warning in a transform in case the data is already correctly formatted, use date-time transform instead of the if transform.
A closer look at my data showed there never was any seconds.
So I went with the JavaScript option and used your script as input for ChatGPT to help refine it. And ended up with this:
function formatTime(h, m) {
    // Ensure the input values are treated as integers
    var hours = parseInt(h, 10);
    var minutes = parseInt(m, 10);
    // Calculate total hours and remaining minutes
    hours += Math.floor(minutes / 60);
    minutes = minutes % 60;
    // Convert hours and minutes to a formatted time string
    var formattedTime = hours.toString().padStart(2, "0") + ":" + minutes.toString().padStart(2, "0");
    return formattedTime;
return formatTime($(h), $(m));
The new MSecsToTime and TimeToMSecs operations in Calculation are now available in v2.1.0:
I just came around to adjusting my transform with this new function.
Worked like a charm :slight_smile:
