I tried to reproduce the problem here, but couldm’t. Perhaps there is a spurious whitespace in that one row? Try pressing the eyeball icon to see any whitespace.
If that isn’t the problem, please send us your .transform file and input data.
1 value does not match ‘Format from’:
‘04-09-2022 0:00:00’ at column ‘FechaNegocio’ row 3
Make sure the date in Quotes has only 1 space between 2022 and 0:00:00. The only way it is not matching if you have 2 spaces between 2022 and 0:00:00. or some other character that is not printable but giving the illusion of space.
Because format dd-MM-yyyy(1space)H:mm:ss that you specified will not match if there is more than 1 space or any other character beside space between yyyy(and)H:mm:ss
Easy Data Transform uses it’s own locale (set in Preferences) and that shouldn’t affect dd-MM-yyyy or dd-MM-yyyy H:mm:ss. Is it possible that one of the characters is a different unicode character to what you think it is?
If it is no trouble, can you please select the original column FechaNegocio in your transform in the right side pane in EDT and copy it.
Then open new instant of EDT by clicking on File->New Window
and in this new instance of EDT click on From Clipboard
Then save the transform and upload it to www.swisstransfer.com as you cannot upload files in here. So that I or anyone else interested in solving this can have access to it.
One more things, can you please also tell, which version of EDT are you using? and if you apply the DateTime Format in the new From Clipboard transform, does it still have the same issue at your end.
So that when we get your new From Clipboard transform file and load it in EDT at our end and face no issues, then it will mean something wrong at your end only.
I missed this earlier in your reply, so it seems it is not a fix repeatable issue, it is kinda random, do you remember doing anything, after which the issue disappeared. Like saved the transform and closed the EDT and re-ran it? or closed everything up and loaded things later, like shutdown the machine and later when you opened up the transform it worked?
And are you using Windows or Mac? because in Windows, if you restart, things which were not working before, starts to work, that is why you will find on internet most of the solutions to problems in Windows, do you have latest updates, did you restart your machine? and it has become a joke that, if something not working in Windows, simply restart your machine and the problem disappears.
