I recently bought a new computer and downloaded Easy Data Transform to continue the work projects I am working on. When I downloaded the most recent version I noticed the stack function is not working properly. Here is the error message it is giving me:
Input 2 (Fake EE File Master - OUM.xlsx[Sheet1], 11 cols x 234 rows) aligned ‘1’ under ‘UniqueEIN’ (column 1)
No one else is having this issue who uses the program. Does anyone know what could be causing this?
Note that there is more feedback on Stack in recent versions, so it may just be a new warning that a columns with different column names are being stacked (e.g. column named 1 is being aligned under a column called UniqueEIN). The output may be the same as before.
