Hi, Not sure if I’ve asked them before but I was wondering. Is it possible to sort a column but putting together all the duplicates together? I don’t want to delete the duplicates, I want all the rows with duplicates in column F to be together.
Thanks Kim
If you Sort by column F, then it should put all the rows with the same column F values together.
Thank you. I have to run my records through three processes but I finally got the end I needed. This will save me so much time!!!
