There is a new snapshot release here:
If you previously visited this page, you may need to refresh it to get the new snapshot.
Changes since the previous snapshot are:
- Fixes issue with output multiple column with same name to XML.
- Adds a right click menu item for filtering the right pane data table.
As a snapshot release, it isn’t as thoroughly tested as a production release, but it should be fairly stable. Please try it and let us know what you think.
