Snapshot release 28-Apr-2026
There is a new v2.12.1 snapshot release with improvements:
  • Easy Data Transform is now better able to repair column references when a Transform, Output or Chart item is disconnected and reconnected.
  • Additional Calculate options for dealing with datetimes:
    • DateTimeAddMSecs
    • DateTimeAddSecs
    • DateTimeAddHours
    • DateTimeAddDays
    • DateTimeAddMonths
    • DateTimeAddYears
    • DateTimeToUTC
You can download the snapshot release here:
As a snapshot release, it isn’t as thoroughly tested as a production release, but it should be fairly stable. Please reply to this post if you have any issues, suggestions or questions related to this release.
This animation shows how you can now disconnect and reconnect to a different dataset with the same column names (even in a different order), without losing all your column references.
reconnecting
