There is a new snapshot release here:
The direct download links are:
Windows: https://www.easydatatransform.com/downloads/EasyDataTransform_1_24_1_snapshot_2.exe
Mac: https://www.easydatatransform.com/downloads/EasyDataTransform_1_24_1_snapshot_2.dmg
The following changes have been made since the previous snapshot release on 15-Feb-22:
- Usability testing showed that beginners are sometimes confused by buttons in the Left pane being disabled when appropriate items in the Center pane are not selected. So now the default behaviour is to keep all the buttons enabled, and show a helpful message if a button is clicked without the appropriate Center pane items selected. You can go back to the old behaviour by checking gray Left pane buttons when not available in the General tab of the Preferences window.
- Fixed an issue where changing a file location in the Right pane for an input or output item and then clicking the Run button cleared the change in the file location.
- The Ngram transform has been enhanced so that it can now sum numeric values in a column instead of counting rows. Set Sum to Rows for the previous behaviour.
This release is on the same page as the previous snapshot release, so you may need to refresh the page.
Please try it and let us know what you think.
