Snapshot release 06-Jun-2026
This snapshot release contains some improvements and bug fixes to the previous v2.14.0 snapshot release:
  • The Folder To Input window layout has been improved on Mac.
  • The Folder To Input window now updates continuously during List Matches. Thanks @MarsKy for feedback on this.
  • Excel sheet name matching is now case insensitive . Thanks @MarsKy for feedback on this.
  • Meta Information is now added after any Schema version. This fixes some issues. It might cause a change in output if you are Schema versioning on a Meta Information column. Thanks to @Olaf for feedback on this.
  • When you drag a folder or file onto Easy Data Transform, it is released immediately, rather than waiting for input to complete. This avoids Windows Explorer or Mac Finder ‘freezing’.
Please try it and let us know if you have any issues or suggestions:
Windows: https://www.easydatatransform.com/downloads/EasyDataTransform_2_14_0_snapshot_2.exe
Mac: https://www.easydatatransform.com/downloads/EasyDataTransform_2_14_0_snapshot_2.dmg
As a snapshot release, it isn’t as thoroughly tested as a production release, but it should be fairly stable.
Works for me. I like the way the file list gets populated as-and-when the files are found - helpful if you have a big list of files and want an indicator on the status of import. The alternative was looking at an hour glass and an empty list for some time.
One thing I noticed is that re-using “Input from Folder”, it seems to remember the Folder at a level up from the previously chosen Folder?
This is only really an issue with Excel files, as we have to open the file to read the names of the sheets, which is slow. With other files types they are listed almost instantly.
I will check that, thanks.
Now fixed. Fix will be in next release. Thanks for reporting.
There are some issues with using a schema when multiple files with different headers from a folder. Hopefully we will get that fixed for the next release.
