Snapshot release 05-May-2026
There is a new v2.12.1 snapshot release. Improvements since the last snapshot release:
  • a new List transform for list operations
  • Count vectors and one hot encoding options for the Split Cols transform
  • improved keyboard shortcuts for the Data table
You can find out more and download the release here:
You may need to refresh the page, if you visited it previously.
As a snapshot release, it isn’t as thoroughly tested as a production release, but it should be fairly stable. Please reply to this post if you have any issues, suggestions or questions related to this release.
some nice features.
The Shortcut changes from point 7. of your list do not work on Mac and the shortcut ar not shown in the window (also not visible in the last official version)
@Olaf I will investigate the shortcuts not working on Mac. Thanks.
I think it is a Mac thing that shortcuts are not shown on pop-up menus. Which makes discoverability hard.
I tried it on Mac and it works for me.
Note that the shortcut keys are:
  • C
  • W
  • H
Not:
  • Cmd-C
  • Cmd-W
  • Cmd-H
o.k. it works with capital C, H, W. Plain letters without Shift don’t work.
As I don’t use the Shift for CMD-C and so on, so I didn’t used Shift now to try the change.
It works for me on Mac with or without Shift pressed.
Restarted notebook, now it works for me, too.
Thanks for analysing.
Strange. If anyone else has the same issue, please let us know.
