I am using the Mac OS X version and the default export results in files with ^M to separate lines.
I have to run mac2unix to process this output before running through other tools. I’d like the ability to select CR, CR/LF, LF as export options.
You can set the line endings where appropriate using the Line endings field. For example for a CSV output:
Thanks. I must have been temporarily blind:)
