Something tricky for me. Convert Row 1-4 to Columns
One way to do this
How else to achieve this?
MyTransform.transform (5.0 KB)
One way to do this
You probably want to check Has header in the Transpose transform.
and if you have the input in one file, add 2 parallel filter transformation on the first column. One “if column 1 is not empty” and the second “if column 1 is empty” and then proceed as in your example with the check set in the transpose, as suggested by admin.
Thanks for the tricks boys
