Running Total equivalent or Unique for Strings
Hellos,
Is it possible to generated Running(Unique) or Running (Non Unique)
Related FMS Master DS This DS Sequence Running (Unique) Running (Non Unique)
3334 1 In Progress In Progress In Progress
3334 2 In Progress In Progress In Progress, In Progress
3334 7 Not Started In Progress,Not Started In Progress, In Progress, Not Started
3336 1 Completed Completed Completed
3336 2 In Progress Completed, In Progress Completed, In Progress
3336 3 Not Started Completed, In Progress, Not Started Completed, In Progress, Not Started
3336 4 In Progress Completed, In Progress, Not Started Completed, In Progress, Not Started, In Progress
3336 5 Not Started Completed, In Progress, Not Started Completed, In Progress, Not Started, In Progress, Not Started
You could use Unique to generate the final state. But I can’t (yet) think of a way to generate the intermediate states.
That’s where I got stuck at too
Maybe javascript , if yes need hlep !
The Javascript transform won’t help, as it only operates on one row at a time.
How about a Lookup with “Bottom values used: All”?
That doesn’t do the cumulative addition.
Yes it is possible.
Transform file.
RunningTotalEquivalent.transform (5.9 KB)
HOLY WOW !! Thank you , studying the javascript right now ! Saved me from making python scripts :smiley:
Nice. I am reminded that the people who design Formula 1 cars are not the same people that race them. ;o)
I am currently looking at additional match options for Lookup, such as contains in addition to exact and fuzzy. It might be a lot easier to do the above if Lookup had an option to match by less than equal.
YESSS !! Will help with string manipulation a lot easier
