Row Number/Index for Multiple Files Output
Hellos,
Since we can output to multiple files , it would be great to have an index or row number for multiple files output .
Currently If I try to output below in multiple files
1|FileA.csv
2|FileA.csv
3|FileB.csv
4|FileB.csv
5|FileB.csv
The idea with index would be to get
File A
1|FileA.csv
2|FileA.csv
File B
1|FileB.csv
2|FileB.csv
3|FileB.csv
Hi Prashant,
what do you intend to reach?
Form my under standing the multiple files out put create the FileA and FileB each with a lot or rows. But not a file per row?
But if you can do row numbering or create a new column with value 1 and use total to do a numbering per group/filename and concat the value with the filename column you use for the output.
I’m not sure I understand what you are trying to do.
Thanks this is precisely what I wanted . Thanks for the reminder on this
Sorry about that , you recently showed me how to do totally by column and I completely forgot it can be implemented here too as an index
@prashant But I‘m still curious what you want to reach, you really want to write each row in a single file?
I wanted to have an index for each (multiple) file which I was generating. So each file has its row index running.
I was able to achieve this with total as per your reminder :smiley:
o.k. you were looking for index within the resulting file :+1:
Your description was a little misleading. Happy to help.
My Bad !!! and thank you
