Requesting a filtering option on column name just like in REMOVE column in Rename window as well.
When working with long CSV 50+ column names , scroll gets tiresome very quickly.
Do you mean a filter that hides some column names (but doesn’t affect the data) in the Rename Cols transform? Or something else?
yes absolutely , that’s what I mean
I’ve added it to the wishlist.
It is now in v2.3.0:
Also for Verify and Unique.
Thanks for this !!
Unique columns filtering is even more helpful , as I can select all fields with ‘QTY’ and immediately SUM them
Cheers ![]()
