I would like to test the artificial intelligence for creating regexes compatible with Easydatatransform. What are the constraints or standards that I need to indicate to the AI in order to create the right regex?
We haven’t tried to use an AI to create a regular expression yet, so we can’t really comment. Perhaps someone else can?
maybe this could help…
As Admin had stated: The Easy Data Transform regex is based on Perl regex.
You can use chatgpt to generate regex or even javascript your require @ANTONIA . Here’s a prompt I use with chatgpt which generates good enough javascripts 99% of times. Maybe a prompt can be created for regex too
I want to make javascript script but I want you to follow these guidelines
Once you understand please give yes/no so I can proceed
Creating JavaScript for Easy Data Transform (EDT) involves some best practices and considerations to ensure efficient and error-free data transformations. Here are some key points:
Key Features and Best Practices:
Variable Handling:
- Use
$(column_number)to reference column values directly. - Always handle potential
nullorundefinedvalues to prevent errors.
- Use
String Operations:
- Use
.trim()to remove any extra whitespace from strings. - Use
.split(delimiter)to divide strings based on a specific character.
- Use
Date Handling:
- Ensure date strings are in a format that JavaScript’s
Dateobject can parse (e.g., ISO formatyyyy-mm-dd). - Always validate date strings before parsing to avoid
Invalid Dateerrors.
Conditional Logic:
- Utilize
if-elsestatements to handle different scenarios, such as checking for delimiters or specific value conditions.
- Utilize
Error Handling:
- Include checks and fallback values to handle unexpected data gracefully.
- Use
try-catchblocks if performing complex operations that may throw exceptions.
Code Readability:
- Write clear and concise code with comments explaining key sections.
- Use meaningful variable names for clarity.
Things to Avoid:
Complex Calculations:
- Avoid overly complex calculations within the JavaScript transform. Use built-in transforms where possible for efficiency.
Unnecessary Global Variables:
- Avoid using global variables. Keep variables scoped within the function to prevent unintended side effects.
Heavy Computations:
- EDT’s JavaScript transform is not optimized for heavy computations. Offload such tasks to dedicated scripts or applications if needed.
Inconsistent Date Formats:
- Ensure date formats are consistent across your dataset to avoid parsing issues.
Ignoring Edge Cases:
- Always consider edge cases (e.g., empty strings, incorrect formats) to make your script robust.
Nitpicks and Extra Tips:
Default Values:
- Provide default values in case of missing or invalid data. For example:
var dateString = $(18) || '';
Regular Expressions:
- Use regular expressions for advanced string manipulations, but ensure they are efficient and well-tested.
Avoid Hardcoding Column Numbers:
- If possible, use dynamic column referencing or document the column numbers to make the script easier to update.
Efficiency:
- Optimize loops and conditionals to run efficiently, especially on large datasets.
Testing:
- Test the script with a subset of your data to ensure it works as expected before applying it to the entire dataset.
Example: Robust Script for Finding Earlier Date:
// Retrieve the value from column 18 and handle missing data
// Function to safely parse dates
function safeParseDate(dateStr) {
var date = new Date(dateStr.trim());
return isNaN(date) ? null : date;
// Check if the column contains the delimiter '|'
if (dateString.includes('|')) {
// Split the dates
var dates = dateString.split('|');
// Parse dates using the safe parse function
var date1 = safeParseDate(dates[0]);
var date2 = safeParseDate(dates[1]);
// Return the earlier date if both are valid, else handle invalid dates
if (date1 && date2) {
return date1 < date2 ? dates[0].trim() : dates[1].trim();
} else if (date1) {
return dates[0].trim();
} else if (date2) {
return dates[1].trim();
} else {
return ''; // or handle as needed
} else {
// Return the original value if no delimiter found or handle as needed
return dateString;
By following these best practices and considerations, you can create efficient and reliable JavaScript transforms in Easy Data Transform.
Thanks a lot. i did not try javascript but only regex delimiter but I think that I misunderstood its function, because i tried alot without success to split a column in three columns using regex to detect the first two spaces in a full name.
