Reform String Format in New Column (Solved)
I am looking to take a string with a constant length delineation and reform. I am getting stuck on the reforming process. Here is an example that illustrates what I am attempting to do using names. Logically I am extracting the two parts, taking the initial and appending ", " then looking to recombine with a string combination in the new column.
Which function or function set would I use to recombine strings into a new column?
recombine.transform (2.7 KB)
Split the columns on the space using the Split Col Transform. These gives you 2 new columns. Then you can Cat Cols in the order you want with the delimiter of your choice.
Or, you can use regex code. This is out of my league.
As @DanFeliciano said, the easy way is to use Split Col and then Concat Cols .
You can also do it with Replace using a regular expression, if you are familiar with regex.
presidents.transform (1.4 KB)
NB/ I’m not an expert on regular expressions! There are plenty of resources online though.
That is a great set of approaches to solve the issue for my needs, thank you @DanFeliciano and @Admin!
