Re-enabling columns in an early “Remove Cols” step affects downstream transforms
Hi everyone,
I’m using Easy Data Transform 2.13 and have run into an issue when modifying an existing workflow.
I remove unnecessary columns near the beginning to keep processing fast. Sometimes I later realise that I need one of those columns and re-enable it in the early Remove Cols step.
After doing this and then selecting another column, some downstream transforms seem to lose or change their column selections, affecting the results.
Keeping all columns until the end would avoid changing the early selection, but that comes with a performance cost for my datasets.
Is there a recommended way to re-enable a previously removed column while preserving the existing downstream settings?
I would upgrade, ether was some fix on downstream topics in 2.14. Afterwards I would restart with the transform file where you had the “wrong” removes in and retry to keep/reactivate the former disabled columns.
If you have a unique key in the table you can alternatively try to lookup the removes column or use join.
Do you have a specific example of this we can investigate? Ideally with a small dataset.
Also, I suggest you update to v2.15.0.
We recommend using Sample to remove rows if you want to improve the performance of large datasets, rather than removing columns. You can check disable sampling when you want to disable sampling to get the full results.
thanks for the quick reply i will update to 2.15 - makes sense :slight_smile: - i try it out maybe the issue would be solved with it - otherwise i try to give you sample transformation with the current issue.
thanks olaf i will update it.
Hi Olaf, i updated it to the current version. Unfortunately the issue is still there. My preferred improvement for EDT would be persistent internal column IDs. Each transform could reference a specific column regardless of its position. If a column is removed, EDT could mark the reference as missing and automatically reconnect it when the column is restored. Is that possible or a good way to solve it?
@Phil Easy Data Transform does use internal column IDs. Are you able to give us a simple example of where this issue occurs. Ideally a .transform file with any inputs and a step by step sequence we can use to reproduce the issue?
i try to send you an example
