I would like to change the format of this phone number 6505615622 to the format below. Is there a best way to do this with EDT? Thank you.
1-(650)-561-5622
1-(650)-561-5622
There might be clever solution using regular expressions or the Javascript transformation. I didn’t see any standard transformation to do so and have only a really lousy suggestion.
Phone Number format (US).transform (5.7 KB)
I was thinking there might be a good regex too for this. Thank you.
You can do it with Replace. There is an example of almost exactly this in the Replace documentation.
One way of doing it through Regex is already provided by @Admin and here is another way.
Set Replace transform as follows
Match Type : Regex
Put in Replace : (\d{3})(\d{3})(\d{4})
Put in With : 1-(\1)-\2-\3
It will transform 6505615622 to your desired output of 1-(650)-561-5622
Thank you for the help.
Ok, thank you for the help.
