i want to output to multiple new sheets in one excel file.
the sheets don’t exist. so i would be writing to a newly created sheet. i want the name of the sheet to be the value in a field.
for example, if i had [cities] with 50 unique values and each city had other related data, then i want one file that had 50 tabs where each tab was a city name and the contents of each tab would be the related data.
i understand that i can have variable file names. but can i have variable sheet names that come from field names? what would be the best way to do this?
Only, instead of writing to multiple files, you are writing to multiple sheets of 1 file. So the output column will have the file and sheet name, e.g.:
i think that the thing i wasn’t sure about was what would happen when you have an output column with the same value. and after your reply and a quick test, i understand that the “write mode” of “overwrite” won’t overwrite previous rows.
rather,
within a run, it appends (each row), and
between runs (when overwrite is chosen), it overwrites .
