Output file name based on column
I have split a file into many smaller files, each of which is for a specific territory (the territory ISO code is stored as a column). Is there a way I can take the territory column value and append it to the filename?
Eg
file 1: filename_AR
file 2: filename_AT
file 2: filename_AU etc
So you are splitting by row values as per example 2 here?:
Just use Concat Cols to add the territory code column to the file name. You might need to Split Col first to separate the file name and extension first.
That worked perfectly, thank you!
