Typically Join operation are done on matches between key columns in 2 datasets and the key values need to match exactly, including case and whitespace.
However, sometimes you may need to do a more exotic join, for example matching when the key value in column A contains, starts with or is a fuzzy match with the key value in column B. You can do this in Easy Data Transform using a Cross transform to add a row for every possible combination of rows, followed by a Filter to remove any non-matches.
join-contains.transform (2.1 KB)
Note that Cross can create very large datasets. A Cross of 2 one thousand row datasets will create a 1 million row dataset. So this technique may not work with large datasets, due to insufficient memory.
