Maybe I am missing an already present feature:
Whenever I choose to disable output upon opening a transform, after fiddling with the transform until I am happy I have to modify for each of the multiple outputs the write mode.
It would be ideal to be able select multiple outputs and modify for all the selected the write mode (overwrite/append/new).
I have some transform that produce 20+ outputs (mostly sheets in a single excel), and it is quite time consuming to go through all the outputs to change them.
Currently you’ll have to do this one output at a time. It is on the wishlist to be able to change multiple items in one operation. But it is a bit tricky because each different input, transform and output can have different properties.
