Meta info reseted on v2.7.0
It’s not a big deal, but it did surprise me. I’ve been adding a file on a daily basis and using a column to record the date each file was added. After updating to v2.7.0, that information was reset, so I just needed to re-enter it.
Just sharing this in case anyone else runs into the same behavior.
Miguel
It was picking up the default meta data string from other input files in the same .transform file. Now it is picking it up from the last meta data edit in any .transform file (made in v2.7.0 or later). You should only have to re-enter it once per file type+extension.
