Lose links in cvs and exel
When I open a cvs or excel sheet, I lose my links. I need my output of the links to be html codes View
Is this possible
Thanks
@Kim
Yes, you can save hyperlink to an Excel format file. Please see section 8 here:
https://www.easydatatransform.com/easydatatransform_v1c0.html
My issue is a bit different because when I download the data, the links are clickable but when I open them in Easy Data Transform the link is gone. It’s not a huge deal, I can change the links in excel before updating my master excel sheet which will be the input files for Easy Data program.
If you follow the instructions above you should end up with clickable hyperlinks in your Excel file.
Sorry, I looked in the wrong section.
