Can i add a descriptive comment to the transforms so I follow the logic easier?
You should follow @prashant’s recommendation. But you should do something more.
Activate in the “View” menu the options:
It shows more information when you move over with the mouse.
Use notes:
You get them with the left click on the mouse.
The comments with the mouse over look like this:
See in the documentation, too: Easy Data Transform
