Hi, I have two columns of dates. I want to merge these two columns but only keep the newest of the two dates in a row. Can I do that?
Thank you
Kim
Thank you
Kim
Yes:
Stack the 2 datasets.
Sort descending by the date column.
Add a Unique transform.
Set the unique key column to Keep unique
Set the date column to Keep first
NB/ Make sure the dates are in a format shown in Preferences.
Simple example:
keep-latest.transform (3.0 KB)
Thanks, the two date columns are on one sheet but I can make it two sheets.
You can do it within EDT, depending on your input file, do two parallel “remove” tasks, maybe you need to rename and then you can process with the stack to merge the split data sets as in the example give by Admin.
