Hello @Admin ,
Please make my dream come true !
Any beta testing needed for writing to SQL , my life will be oh so so easier.
Hello @Admin ,
Do you mean:
To convert a .transform to the equivalent SQL?
or
To be able to output directly to SQL databases?
The first is unlikely. The second is on the wishlist.
OUTPUT TO SQL directly !!
Input from common SQL databases or connectors would be very cool, too, although a CSV dump of each table pretty much provides the same possibilities.
Reading and writing SQL databases would be awesome. How to handle race conditions for updating a single SQL database used as both input and output might be a real trick, though.
Before I started using EDT on a daily basis, I was spending 80% of my time searching, cleaning, and arranging data (for different departments and myself), and only 20% of the time actually using it. Once I adopted EDT, this ratio quickly reversed. Suddenly, I found myself with an increasingly large volume of clean, well-formatted data. That was a completely new and unusual situation for me.
I had previously used Microsoft Access a little, but as the amount of data grew, it quickly became more of a toy than an effective tool. GPT soon pointed me towards SQLite and DuckDB. After some testing, I chose DuckDB + Python + Streamlit. I tried several IDEs for databases, but none of them really suited me. While using them, I realized that the tool and interface I really want to keep is EDT.
I did use EDT to teach GPT how to perform certain ETL operations, but only for small transformations. For long and complex transformations, I want—and will continue—to leave them in EDT, nowhere else. It’s so satisfying to throw in two or three files, create a tree of solutions leading to 7, 8, or 9 outputs, all within the same interface. That’s priceless.
So, since EDT doesn’t “speak” DuckDB, I use CSVs as a kind of “poor man’s API” between the two systems. It’s not optimal, but it works, and it means I don’t have to choose between one system or the other—I keep both.
Being able to read and write directly from/to DuckDB databases is somewhere on the wishlist.
For your information, I use Hyperplan (https://www.hyperplan.com) mainly to visualize the status of the most important Python logs. At the moment, I have one script that extracts data from the HP file into a CSV, another script that modifies the CSV, and a third script that pushes the changes made in the CSV back into a new HP file.
So, when EDT has finished its work, or when DuckDB has finished its work, or when Python has finished its work, I can also track the ongoing status of the tasks through Hyperplan. I see EDT and HP as a single program—one for DOING and the other for SEEING.
a video speaker louder than 1000 words !! Would love to see
Not a video but the items to build your own
hyperplan_schema.json (220 Bytes)
Python script:
Hyperplan XML ⇄ CSV — Generic, colleague-friendly
Goals:
• Works out-of-the-box by just pressing Run in an IDE (autorun).
• Detects headers in three ways (priority order):
1) Embedded <columns><col name="..."/></columns> in the .hp
2) Sidecar schema JSON: <basename>.schema.json or hyperplan_schema.json
Example:
"headers": ["Subject","DataProvider","Operator","Country","Tier","NextRun"],
"include_notes": true,
"include_image": true,
"include_links": true,
"csv_encoding": "utf-8-sig",
"excel_friendly": true
3) Fallback default headers: ["Subject","DataProvider","Operator","Country","Tier","NextRun"]
• Export adds optional Notes/Image/Links columns (configurable).
• Also supports CSV → XML rewrite using the same schema.
• Autorun behavior:
- If only .hp is present → export CSV
- If CSV exists (cards_export.csv) and .hp exists → ask to (R)ewrite XML or (E)xport again.
import xml.etree.ElementTree as ET
import pandas as pd
from urllib.parse import quote, unquote
from pathlib import Path
from datetime import datetime
import csv, os, sys, json
DEF_HEADERS = ["Subject","DataProvider","Operator","Country","Tier","NextRun"]
def get_latest_hp_file(path="."):
files = [f for f in os.listdir(path) if f.startswith("hyperplan_") and f.endswith(".hp")]
if not files:
raise FileNotFoundError("No 'hyperplan_*.hp' file found in the current directory.")
files.sort(key=lambda f: os.path.getmtime(os.path.join(path, f)))
return os.path.join(path, files[-1])
def load_sidecar_schema(hp_path: str):
"""Look for '<basename>.schema.json' then 'hyperplan_schema.json'. Return dict or None."""
p = Path(hp_path)
cands = [p.with_suffix(".schema.json"), p.parent / "hyperplan_schema.json"]
for c in cands:
if c.exists():
try:
with open(c, "r", encoding="utf-8") as f:
data = json.load(f)
if isinstance(data, dict) and "headers" in data and isinstance(data["headers"], list):
return data
except Exception:
pass
return None
def read_embedded_columns(root):
"""Parse <columns><col name='...'/></columns>. Return list[str] or None."""
cols = []
cols_node = root.find("columns")
if cols_node is None:
return None
for col in cols_node.findall("col"):
name = col.attrib.get("name") or (col.text or "").strip()
if name:
cols.append(unquote(name))
return cols or None
def detect_headers(root, hp_path: str):
# 1) Embedded columns
embedded = read_embedded_columns(root)
if embedded:
return embedded, {"include_notes": True, "include_image": True, "include_links": True, "csv_encoding":"utf-8-sig"}
# 2) Sidecar schema
side = load_sidecar_schema(hp_path)
if side:
return side.get("headers", DEF_HEADERS), {
"include_notes": bool(side.get("include_notes", True)),
"include_image": bool(side.get("include_image", True)),
"include_links": bool(side.get("include_links", True)),
"csv_encoding": side.get("csv_encoding", "utf-8-sig")
# 3) Default
return DEF_HEADERS, {"include_notes": True, "include_image": True, "include_links": True, "csv_encoding":"utf-8-sig"}
def parse_card_value(value: str, expected_fields: int):
parts = value.split(",")
# Pad to expected_fields length
while len(parts) < expected_fields:
parts.append("")
# Truncate extras (rare) to keep CSV width stable
parts = parts[:expected_fields]
return [unquote(p) for p in parts]
def decode_notes(text: str):
return unquote(text) if text else ""
def decode_links(links_elem):
links = []
if links_elem is not None:
for link in links_elem.findall("link"):
links.append(unquote(link.attrib.get("value", "")))
return "\n".join(links)
def xml_to_csv(xml_file: str, csv_file: str):
tree = ET.parse(xml_file)
root = tree.getroot()
cards_elem = root.find("cards")
if cards_elem is None:
raise ValueError("No <cards> element found in the XML file.")
headers, opts = detect_headers(root, xml_file)
rows = []
for card in cards_elem.findall("card"):
values = parse_card_value(card.attrib.get("value",""), expected_fields=len(headers))
row = values[:]
if opts["include_notes"]:
row.append(decode_notes(card.attrib.get("notes","")))
if opts["include_image"]:
row.append(card.attrib.get("image",""))
if opts["include_links"]:
row.append(decode_links(card.find("links")))
rows.append(row)
# Build final header list
out_headers = headers[:]
out_headers.append("Notes")
out_headers.append("Image")
out_headers.append("Links")
df = pd.DataFrame(rows, columns=out_headers)
encoding = opts.get("csv_encoding","utf-8-sig")
df.to_csv(csv_file, index=False, header=True, quoting=csv.QUOTE_ALL, encoding=encoding)
print(f"âś… Exported {len(df)} cards to '{csv_file}' with headers: {out_headers}")
def encode_card_value(values):
return ",".join([quote(str(v)) for v in values])
def encode_notes(text: str):
return quote(text) if text else ""
def encode_links_block(links_text: str):
# Return XML block for links or empty string
block = ""
for line in str(links_text).splitlines():
path = line.strip()
if path:
name = Path(path).name
block += f' <link value="{quote(path)}" link_name="{quote(name)}"/>\n'
if block:
return " <links>\n" + block + " </links>\n"
return ""
def csv_to_xml(csv_file: str, xml_input_file: str, xml_output_file: str):
df = pd.read_csv(csv_file)
with open(xml_input_file, encoding="utf-8") as f:
original = f.read()
# Extract headers config again to know how many leading fields belong to 'value'
tree = ET.parse(xml_input_file)
headers, opts = detect_headers(root, xml_input_file)
start = original.find("<cards>")
end = original.find("</cards>")
if start == -1 or end == -1:
raise ValueError("No <cards> block found.")
end += len("</cards>")
cards_section = "<cards>\n"
for _, row in df.iterrows():
# Map first len(headers) columns into the 'value' attribute
values = [row.get(h, "") for h in headers]
value_attr = encode_card_value([str(x if pd.notna(x) else "") for x in values])
# Optional attributes
notes_attr = ""
image_attr = ' image="-1"'
links_text = ""
if opts["include_notes"] and "Notes" in df.columns:
notes = row.get("Notes","")
notes_attr = f' notes="{encode_notes("" if pd.isna(notes) else str(notes))}"' if (pd.notna(notes) and str(notes) != "") else ""
if opts["include_image"] and "Image" in df.columns:
image = row.get("Image","-1")
image_attr = f' image="{str("" if pd.isna(image) else image)}"'
if opts["include_links"] and "Links" in df.columns:
links_text = "" if pd.isna(row.get("Links","")) else str(row.get("Links",""))
# Build card
links_block = encode_links_block(links_text)
if links_block:
cards_section += f' <card value="{value_attr}"{notes_attr}{image_attr}>\n{links_block} </card>\n'
else:
cards_section += f' <card value="{value_attr}"{notes_attr}{image_attr} />\n'
cards_section += "</cards>"
updated = original[:start] + cards_section + original[end:]
with open(xml_output_file, "w", encoding="utf-8") as f:
f.write(updated)
print(f"✅ Rewritten XML with {len(df)} cards → '{xml_output_file}'.")
def get_timestamped_filename(prefix="hyperplan_", ext=".hp"):
now = datetime.now().strftime("%Y%m%d_%H%M")
return f"{prefix}{now}{ext}"
def autorun():
cwd = Path(".")
hp = get_latest_hp_file(".")
csv_path = cwd / "cards_export.csv"
if csv_path.exists():
# Ask user what to do
print(f"Detected existing CSV: {csv_path}")
choice = input("Press [R] to rebuild XML from CSV, [E] to export CSV again, or [X] to cancel: ").strip().lower()
if choice == "r":
out_xml = cwd / get_timestamped_filename()
csv_to_xml(str(csv_path), hp, str(out_xml))
return
elif choice == "e":
xml_to_csv(hp, str(csv_path))
return
else:
print("Cancelled.")
return
else:
if __name__ == "__main__":
try:
autorun()
except Exception as e:
print(f"❌ Error: {e}")
sys.exit(1)
