If note is too long it is difficult to read, is there anyway to change font size?
Regards,
Msaiz
Regards,
Msaiz
Do you mean in the Center or Right pane?
The text in the Center pane scales to fit and is truncated beyond a certain length. You can’t change the font size directly. But you can hover over it and view the tooltip. You can also use the new magnify cursor, see the new v1.44.1 snapshot release.
You can also set the font for the whole user interface (including the Right pane) in Preferences>General.
