Hello o/
I have XML (~4MB) file with n-levels nested structure.
Opening it as LONG, 149 cols.
Issue:
Every time I run EDT and open same .transform - it open exactly same, unmodified XML in different cols order (??).
My first step is “Remove Cols” (so only 5 cols is left) - and now it is removing different cols each time when I open this .transform file, so everything downstream (20+ steps) is wrong…
It is known issue?
I do not want to share whole file because its content.
Did some search - the “header-only.csv” trick will solve this? →
Yes, you should be able to use a Stack transform to handles this, as described in the link provided. However the same XML file input with the same settings should produce the same dataset each time. If you can provide us an example where that isn’t the case, we will investigate. If the data is sensitive, you can email it to support. Or perhaps you can create a non-sensitive example that displays the issue?
