Hi, I need to update the dates on sheet 1 to the dates on sheet 2. I need to do it by using the matching number to know what date to update. I have no idea how this.
sheet1.csv (63 Bytes)
sheet2.csv (95 Bytes)
Any thoughts?
Thank you
Kim
Any thoughts?
Thank you
Kim
You can do this with a simple Join. Then Remove Cols to get rid of the original dates.
https://www.easydatatransform.com/join_csv_files.html
Thanks, I was over thinking it.
