We are looking into trying to handle converting from all the major international number formats in the Num Format transform. These are the formats we are aware of:
v1.44.1 can convert Indian locale numbers to other locales using Num Format.
When converting to US, UK or European etc numbers to Hindi/Indian locale it doesn’t seem to get the digit grouping right. The Qt framework we used doesn’t seem to fully support Indian number grouping. I guess you could use Replace or Javascript and regex to do it? E.g.:
BTW We reported this issue to Qt a while back. Apparently it is fixed in Qt 6, so should be fixed in Easy Data Transform when we move to Qt 6 (probably for Easy Data Transform v2). https://bugreports.qt.io/browse/QTBUG-116620
