When I use a sort node (descending) on a column it sorts like this:
986
94
938
91
900
9
875
But I want it to sort like this:
986
938
900
875
94
91
9
Is there a setting I am missing?
986
94
938
91
900
9
875
986
938
900
875
94
91
9
I think the column Comp is interpreted as characters, the “,” is not interpreted as number separator. Therefore ist sorts a you show. Maybe you need to check your settings.
When I remove the , or remove it, the row is interpreted as number (I have German settings) it works as I think you expect it:
Sort_Num_Format.transform (3.8 KB)
Ah yes. I think you are on to something. Thanks for the transform Olaf. I tried your solution (replace) and a few other tweaks but it didn’t quite fix it, but I think you are right that it is not interpreting it correctly, I just can’t find where to set that in a way that solves it. I have only tried a few but I think the solution is in this approach. Thanks!
SOLVED
I added a Num Format with the default setting but changed the setting “Non-Numeric” to “Change to 0” and it sorts correctly now.
The problem seems to have been that 3 entries had “< 20” instead of a number.
Thanks for the help!
by the way, sometime it helps to understand what happen to use the “value analysis” (I don’t know how Andy names this correctly
Are commas recognized as thousand delimiters in your choice of Locale in Preferences? If not, it won’t recognize 2,000,000 as a number. Try making a copy of the column with Copy Col and removing the commas with Replace. If that does’t work please email support a small example showing the problem. Or you can change General>Locale in Preferences.
Thank you!
You may have missed my post above where I mention that I solved the problem (and how)
SOLVED
Thanks as always for the help and good tips!
