Hi, is it possible to add a new column with a static sequence of numbers?
Row Num transformation adds such
https://www.easydatatransform.com/help/20/mac/html/index.html?row_num.html
Thanks I used it but it has a dynamic behavior. If rows quantity in subsequent transformations vary, numbers vary too ![]()
If you have a key field which is the master you can check the HASH transformation, maybe this gives what you need.
https://www.easydatatransform.com/help/20/mac/html/index.html?hash.html
I’m not sure what you mean. Can you give an example?
I need a sequence of numbers that are binded with other fields, once generated. Static. Don’t know if I was clear.
they will be part of the row once generated, and not vary changing other columns.
But why do you think that that a row number added once, does change later on? If you don‘t manipulate the value it will stick as every other field.
I thought it was so but i couldn’t obtain what I searched. It seems that the values change in a manner that I can’t understand once firstly created.
Can you share what gave you pain and you had changes?
Sorry, that still isn’t clear. We really need sample input(s) and the corresponding output you want.
