I would like to statistically evaluate many values with different dates. This evaluation should only be carried out for the same date, but for all dates.
I would be happy if someone could give me a tip
What type of statistical measure are you trying to calculate?
You can do min, max and sum per value in a date column using Unique.
You can do the following with Pivot:
See this example:
stat by date.transform (2.3 KB)
Thanks for your help
