The new Find + Replace is awesome, especially for header names.
The REPLACE transform function allows exporting. Can we also export the new find + replace datasets?
In Rename Cols the replace feature only replaces 1 string at a time. So I’m not sure how useful it would be to import/export that. After all you can just copy the Replace or With term to/from the clipboard like any other text.
