Hey another question. I think it might be a regex issue more than a Easy Data Transform question. I’m trying to extract a text between brackets. I’m starting with :
Basically the idea is to get rid of the “NAMEOFIMAGE.png” and get rid of the brackets. As the length of “NAMEOFIMAGE” vary I could not use the “Chop” function.
Cheers,
Y.
Dear Regex Master, I have an other request/question. Same kind of topic so I feel I should not create another one.
I’ve got these kind of columns
21. EXT. FOREST - DAY
22. INT. HOUSE - MORNING
24. INT. / EXT. CAR - NIGHT
I’d like to replace data to obtain three columns. First one with these values. This is separated by a coma but should be in column
21,22,24
then another column with
EXT,INT,INT/EXT
then another one with
FOREST,HOUSE,CAR
and a last one with
DAY,MORNING,NIGHT
I managed to extract the numbers using regex, [^(>) \d\d]* and replacing by nothing but I struggle with the rest.
Thanks in advance for any help,
Y.
