Hello,
I am using v 1.25 (same issue in 1.25.1), was there a change in the library used to output data?
I am working on a single CSV input and after processing, when choosing the output currently the CSV option is not here anymore, replaced by Excel XLX File (CSV) which does not produce a CSV file.
And when outputting to the first option (*.) it is impossible to name the file output.csv (see below)
Thank you!
Problem solved.
Weird that it happened as I did not enter the preferences for a very long while and never modified that tab preferences.
Gremlins!
