A Create Pattern Transform would be useful.
This is a description from Minitab.
Use Make Patterned Data to generate repeating sequences of numbers, text values, or date/time values. You can repeat a sequence of equally-spaced numbers or date/time values, unequally-spaced numbers or date/time values, or text values.
For example, a quality engineer wants to measure parts from three machines, at two temperatures, during every work shift for a week. The engineer generates columns of patterned data for the machine ID, temperature setting, and work shift.
I had considered having a way to generate datasets. For example for testing. it could allow for generating sequences or random numbers, dates or strings. This might work better as a new type of input, rather than a transform.
