yes it does it.
I have now to extend it, so that this works for a variable set of control columns. But I think with your idea I can go on.
Thanks,
Olaf
I just wanted to say some words how I made it more flexible for changing number of sequences in the control file.
I created with the “split into multiple file” functionality one file per sequence.
Then I build the join part of the individual created control files. This part I run in command line mode with a loop for each created control file. I this I use the multiple-file output functionality to name the export file using part of the name of the input control file (meta data).
I real like the batch and the command line functionalities.
I used the command line loop here, as I run both transformations in one script. In EDT you can do the same with batch mode, using a wildcard for the control file input.
