Concatenate: Brand + Type, with a space delimiter = “BrandType”
I can’t concatenate the next sequence (Concatenate BrandType + Column Number, with [#] delimiter) because the new column, “BrandType” is added as the last column.
I don’t know if it will help you in this particular case but the alternative workflow trick I have successfully used before is as follows:
First use the GATHER transform on the separate data tables using BATCH mode and the output set to APPEND to add them all together into one big table, then SORT & FILTER the fields as you need, and then when the data is ready, use a final SPREAD transform.
