Original Dataset
Using Concat Rows - Mode BY Key (Relation) I am able to get below output
Expected output
Concat Rows.transform (3.1 KB)
Original Dataset
Expected output
Thank you for the solution.
I agree ! Maybe another bucket list item for V2
I was hoping for non brute force way since CONCAT Rows already did 50% of the job
Thanks @Anonymous
Appreciate it
Another way, but it is not exactly as per your output requirement.
Transform file
RelationGuest2.transform (4.2 KB)
Not same, because you are missing the Relation ![]()
Thank you both ! I was also hoping to do spread @Admin !
Unique didn’t strike me only @Anonymous !
Yeah it’s the relationship column which is annoying , the actual table had two more columns such as Relationship to be repeated , I thought whatever is the way to do two , will apply on 4 .
