Hi, new user here, so please be patient ![]()
I have a couple of Excel files which (since my locale is German) have the comma as the digit separator (e.g. 25,6).
How can I transform those to 25.6 which is what I need?
I want to stack the files but also clean them up at the same time.
Thanks for any help!
I have sometime the opposite one, get logging files with . and want to have the (German) β,β
I just use the Replace transformation, select all number columns and change β,β to β.β or vice versa. If the value is already correct the replace will do nothing.
You can change the locale in Preferences. But probably better to use Replace, as suggested by @Olaf.
replace-comma.transform (1.4 KB)
Many thanks to @Olaf and @Admin (Andy) for the speedy reply!
One more question: Can I swap columns? I would like to swap columns 3 and 4.
Yes, use the Reorder Cols transform.
https://www.easydatatransform.com/help/latest/windows/html/index.html?reorder.html
Not seeing the forest for the trees⦠Thanks a bunch!
All the different transforms can be a bit overwhelming at first. But hopefully you will soon get used to them. Note that you can type keywords to find transforms in the left pane:
