I really appreciate the Calculate transform and use it all the time. Would it be possible to input a number in one of the parameters rather then reference a column? For Example, Divide column Current Read by 10 or add 25 to column B or multiple column C by 100.
You can add a new column with the constant value and then remove it afterwards, but that is a bit long winded. I will add it to the wishlist.
I looked into this a bit more. It is trickier than it looks, as the constant can be a number (real or integer) or a date. But I will bear it in mind.
