Hi, I have 10 of the same modules that all need to be changed.
In this case, all my “ifs” need the column changed to the same column.
Is there a way to bulk edit modules?
Thank you
Kim
Thank you
Kim
While I still would like this feature. I just realized I think, I could have used count and got the same results, and this long process I wrote
Currently there isn’t a way to edit multiple items at the same time. It is on the wishlist to be added in future, but is made more complicated by the fact that all item can have different options. As well as transform options between different, input and output items have different options depending on the file type.
