I got several .json files and I would like to extract some columns. When I do the individual filtering with “remove columns”, all looks fine but in batch process the results “drift” and are unusable.
Lets say, I want to extract “contentId” and “contents.0.medias.0.src.file” files from the attached databases. Seems simple task but batch does not work.
But the column names are the same ? Probably im missing something…
Also, can You pls explain how to use Stack ?
I got about 4000 json files - actually these are radio station timetables - and I want to extract “Program name” and “Start time” etc to excel file. Which would be about 20000 … 40000 lines.
I checked, the field names are the same no matter when the json is made (from 2011 to 2023 year)
Ok, I missed the link you added. I understand that link but Can You pls help how to define BATCH with 2 inputs - one stays the same but other is changing.
