Hi, I need to export a file with these instructions “The file as an ASCII fixed width text file with no delimiters and it must have the .TXT extension to the filename” is that possible?
Thank you
Kim
Thank you
Kim
Do you mean you want the instruction string added to a file?
Or do you mean you want to export a file that matches the instructions?
Either is possible.
I meant the output file needs those settings. I was not sure how to set that up in the output to file window.
Thank you
You can use the Pad transform to pad each column with spaces to the required width and then export it as Plain text format.
