Hello! Is there a way to add a two input function into an already existing thread. Example.
Ive created a full conversion, but now I want to add an additional input that I want to go through that same conversion. What I would do is add another input file, then stack that early in the conversion so that file could go through the same conversion process. If its an easy one and im missing it I apologize. I know you can right click on the lines between the boxes and do inputs, but I dont see that it will allow me to do a lookup or a stack as an example.
If I “break” that first input to add the stack in, then it hurts the converter downstream.
Not sure if you ever thought of it, but it would be cool to have some type of “freeze” feature that basically froze the converter as is until you get your changes made and then unfroze it and allowed it to process. sometimes having to break the thread upstream is a punishment!
